Hi again, sorry to make so many posts in the same day...
I was wondering if anyone has had experience replacing the LCD screen on their N95.
I'm asking as mine has some pretty bad scratches (From where dust got inbetween the screen, and a 'body glove' case)
I can get one off eBay for about �30, with the appropriate tools. It says it's a genuine Nokia item but I don't want to end up buying a cheap chinese replacement.
If anyone has done it, is it easy? What should I watch out for?
Also, does anyone have a link to the 'wobbly slider' fix? Mine has the looseness in the lower right hand corner. This makes a 'tapping' sound when I press the red 'hang up' button.
Thank you all
Andy
