hi there, can anyone recommend a good sturdy air vent car cradle for my N95?
Must have possibility to connect charge at bottom.
Any recommendations on models and where to buy (uk)
thanks!
thanks!
Google for Brodit active cradles. I have been using one for about 4 months and its been perfect.
thanks
I made an active holder using a �4 universal car charger, and a couple of bits off of a cheap nokia desktop charger. It works brilliantly and cost me a total of �8. Il take some pics if you are interested!!
very interested mate. pics/procedure would be great please !
Brodit is such a rip off ... �30 ... too much.
Here are some badly taken pics but you get the idea
This was 1st attempt. I just made a better one for my girlfriends dad!!
Some more :icon14:
nudda wrote:very interested mate. pics/procedure would be great please !Brodit is such a rip off ... �30 ... too much.
Not a rip off at all. It might be expensive but it's worth it. The thing is with Brodit you get a holder specific for the phone and a clip specific for the car then screw them together. This is perfect becasue if you change car, you can use the same phone holder and if you change phone you can use the same clip PLUS the clip is a firm, natural fit that looks factory and requires no drilling glueing or suckers AND the holder is carefully designed so it doesn't push the buttons on the sides of the phone and therefore activate the gallery which most universal ones do
thanks yade
can you give instruction on how to make that please including where the parts are from ? It looks realllyyy good and I want one just like it
thanks again !!!!
Yade where did you get your theme, I like the bright blue clock :icon14: :icon14:
good point lee, i like that too !!!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140158428692
This is the universal holder
http://l8shop.net/products/Twin-Desktop-Charger-Nokia-N95.aspx
The desktop charger I swiped the bits from!!
i love it ... thanks a lot !
any pointers on that theme you got ?
Oh yeah, It's called NokiaNserries4V2NIbyP@sco
I got it on here!!!
Hi all...there's a really good craddle on play.com for the nokia95 and it also has a charger facility attached. The craddle plugs directly into your cigrette lighter and it looks nice and neat. Its very good and cheap (�4.99). Its def worth the money!
For the theme go here guys/gals.
