Anything i should know before replacing SeleQ with FExplorer? I want the smaller size... SeleQ is rather HUGE [even tho its only 95k with Stacker60] but even so... I think im gonna replace it.
Replacing SeleQ with FExplorer [latest ver]
I did that, and I miss nothing.
Go ahead.
SeleQ has lots of more features then Domi's FileExplorer,Like the Oplogo feature,gif viewer etc etc.You dont have those with fExplorer.
I dont need those kind of features so i use fExplorer.
[quote="Zipper"]Anything i should know before replacing SeleQ with FExplorer?[/quote]
Well, first of all since you PAID for seleq, I would keep him just for that :P (well, if you were using trial version of seleq, then I'd suggest to GO for the free one (fExplorer)!)
and then, here are a quick, non comprehensive, list of SeleQ features that fExplorer does not (yet) have:
- browsing with phone keys that do the "PgUp" and "PgDn" functions: I really like this one in SeleQ 😊
- text editor
- operator logo with one click
- other little cosmetic things 😊
also, they are slightly different in the way they are used; I mean: psiloc's filemanager is different too, so when you get used with one program, you must take some time to "learn" how the other one works
but fExplorer is a great work 😉 and the best thing of all is that it is FREE... and it's strange that we still haven't seen newer releases of other filebrowsers with added features :P
faquick,
thanks for the 'not yet' in your mail !!!! 😃 😃
humm .. the editor of SeleQ, I don't think it's a editor ... have you already try it ???
PS: I'm also a register user of SeleQ (I have paid for it before the born of FE...)
I'm currently working on a really ( 😉 ) editor !!
Domi.
[quote="Domi"]thanks for the 'not yet' in your mail !!!![/quote]
Well, that's just the truth 😉 I know you're working hard on that program, and every new release includes lots of additions, so I was quite sure you'll be introducing even more features in the future 8)
Actually I only use that function as a "viewer" because I prefer it to the "notepad" standard view... I never tried to save a file... if it could be done :P
Very nice!! Count me on for beta-testing 😉
p.s. didn't you forget to login here? :angel:
SeleQ is still have best appl in the market. Given a choic i will still go for SeleQ 8)
All things taken into account... I will stick with SeleQ untill the next version of FExplore - If its nearlly as goodd as SeleQ now - it must be MUCH better than SeleQ after a new release!
DOMI - PLEASE count me in for Beta testing!!! I beta tested sAnser60 and Stacker60 😊 I liked it 😊
PS. Stacker60 is Excellent!!! Its the only one! And sAnswer60! - Its MARVELOUS!!!! Most impressive!
Care to post screen shot of Stacker60 and sAnswer60??
[quote="Zipper"]All things taken into account... I will stick with SeleQ untill the next version of FExplore - If its nearlly as goodd as SeleQ now - it must be MUCH better than SeleQ after a new release!
PS. Stacker60 is Excellent!!! Its the only one! And sAnswer60! - Its MARVELOUS!!!! Most impressive![/quote]
Just to calrify,i dont think that Domi has anything to do with Stacker and SA 😃
[quote="GhostDog"][quote="Zipper"]All things taken into account... I will stick with SeleQ untill the next version of FExplore - If its nearlly as goodd as SeleQ now - it must be MUCH better than SeleQ after a new release!
Just to calrify,i dont think that Domi has anything to do with Stacker and SA 😃[/quote]
Yeah i know [hence a PS]
And a screen shot for the fella' above - [PS Im gettin Fastxt popup's Grrr]
And some more
Theres more options under the settings menu etc... But i lacked the 'be-botherdness' to take more shots ... I dont have sAnswer60 installed at the moment but there are shots around of it
im one of those really big seleQ fans - and actually i still am! it's a great app and actually its the very first app i purchased for my 7650. but, i really like using fExplorer better. smaller in size and the feature are almost the same! its what i use now. 8)
keep up the good work, Domi! 😉
