N95 as handsfree to computer?
1 replies · 1,740 views · Started 02 October 2007
Hello, had P810i it could work as a handsfree to my computer connected via blue tooth (e.g. with IP telephony or listen to recordings). Anybody knows if this works with N95?
Hi, as far as IP telephony goes the N95 supports VOIP directly so there is no need to use the PC!
(Check out Truphone & fring)
For listening to recordings I would have thought that bluetooth headphones would be better. The Nokia BH-500 BT headset has a 3.5mm socket to accept any headphones you like, and also comes with an adaptor to link it to your PC without the phone.
