Mp3 Player Help
3 replies · 2,040 views · Started 03 October 2007
is anyone aware of an aftermarket mp3 player for the n95 that allows you to turn the volume up using the interface rather than the volume key on the side of phone(broken key) any help will be much appreciated thanks.
doesn't the headphone kit that came with the N95 allow this? I thought it did, but mine's at home so can't check.
chrsfrwll wrote:doesn't the headphone kit that came with the N95 allow this? I thought it did, but mine's at home so can't check.
Yes, you can change the volume with the headset.
i never thought of using the head set. would be probem solved but it would appear that my headset doesn't work either! what chance have i got! any ideas?
