I have recently got this program, but I am unable to connect to my account. Do you have to change any settings regarding ports, servers, etc?
IM+ 2.14
are you able to connect with other programs (i.e. mailbox, wirelessIRC, teletext viewer) using your current access point (or gsm data call number) ?
Is there a difference between 2.0 and 2.14? i couln't find that anywhere..
Wish I could just download IM with msn and without icq and such. (size 😉 )
can someone tell me how to connect to msn??
i can connect to other programs but not msn
I had trouble earlier connecting but it seems to be fine now. I don't use GPRS, I connect through bluetooth on my PC's net connection. But I prefer TipicME after trying IM+ 2.14. Other than it being much smaller, I think it's easier to use and the interface is nicer.
does TipicME work properly with GPRS ?
It's working fine for me. Sometimes it's slow and can't report properly online/offline status of your contacts, but it's due to overload of the Tipic.com server. Usually, it's fast and reliable.
Can i use msn with tipicme??
yes - you can use MSN with tipicme
[quote="simply258"]I had trouble earlier connecting but it seems to be fine now. I don't use GPRS, I connect through bluetooth on my PC's net connection. [/quote]
Hello! Me dummy, you smart!
Can you tell me how you setup the BT-system to be connected via PC-connection???
I have Racewood BT-Dongle whit widcomm 1.2.???? drivers.
Try the
Search. This has been discussed too many times already.
how do i Turn on my msn??
i get connected to TipicME but then i dontknow how to turn on msn
^_^can someone plz tell me
ok i got the msn thing working but now i get a message wating server response and its stuck on that
