Is is possible to set radio as an alarm on nokia95? I would like to wake up with the sound of radio. Please answer.
Best Regards
Opcje Warrantow
Best Regards
Opcje Warrantow
No,is not possible.
hmm not so sure its impossible..
ive seen apps that are capable of launcing other apps based on certain events.. im sure it could be set to launch radio at certain time...
but the sound would come out the headphones by default not loudspeaker. so you would have to leave your n95 plugged into a speaker set for it to work, inwhich case you might aswell just buy a radio alarm clock as they are very cheap these days!
