Hi, I'm trying to figure out how to do that, but don't know what to do.
I've found this: rtsp://stream2.visual.cz/broadcast/ct/ct24-low.rm
Is it streaming link?
In gallery/streaming links I added new and typed the link
but when I try to open it it says: Unable to connect, Invalid URL address
and i've noticed that it is trying to connect via the 3g and not wifi as I want to.
What I'am doing wrong?
ok,
another thing I tried was connect to the internet via wifi and click stream link (I thought that I am already connected, so I wont need to connect with player). But it again tried to connect by 3G (those arrows under the reception).
Can I somehow setup player to play via wifi?
Go into Realplayer --> Options --> Settings --> Connection --> network --> Default Access Point
And change that to your wireless access point.
Thx for that, now it is connecting, but it is always unable to connect or connection timeout. I tried to switch of and on proxy but it didn't help.
Is there any settings I should change?
PS: Internet works normally on the phone.
ok, I tried more links (from: http://allaboutsymbian.com/forum//forum/thread/48036/) but still: unable to connect.
What I'm doing wrong?
cheers
I'm just trying to revive my post. I won't do it twice 😊
Any idea what's wrong?
Does this link: rtsp://stream2.visual.cz/broadcast/ct/ct24-low.rm work?
thx
Hi used to have the same problem. What you need to do is go to your router settings and place your N80 outside the DMZ (demilitarised zone) usually found under advanced settings. It will then be able to stream links.
I tried your link it doesn't work. I don't have enough posts to be able to post a working link!
Thx, heaps, I'll try that
Could you send me that link to PM please?
