Nokia Device Status
2 replies · 2,723 views · Started 09 October 2007
Picture program on PC:
Some pictures program on N95:
User posted imageUser posted imageUser posted imageUser posted imageUser posted image
Overview:
Nokia Device Status is a self-diagnosis tool that allows you to collect detailed system information both from your PC and your S60 device. Your current device configuration and phone settings are presented in a detailed summary, which you can use to determine the exact cause, if you run into problems.
With Nokia Device Status, you can save all the collected information to a file, and you can send the file to customer care services for closer inspection and analysis.
Collected data from your PC includes:
Operating system
Language of the operating system vs. that of Nokia PC Suite
Version of Nokia PC Suite currently installed on your PC
Drivers required to connect your phone to your PC
Local time zone
Log files created by Nokia PC Suite
Regional and language settings
Collected data from your phone includes:
Device model
IMEI code of the phone
Device memory and any available memory card
Profiles and themes used on the phone
Locations used to store data on the phone
After installation, you can access the application both from your phone and from your PC.
We are evaluating the possibilities for integrate Nokia Device Status with Nokia customer care, so tell us what you think - all improvement suggestions are warmly welcome!
Installation instructions
Before installation, please remove possible earlier versions from your PC and your phone. Also, make sure that you have Nokia PC Suite (6.84 or newer) or Nokia Nseries PC Suite installed on your PC.
http://nds1.nokia.com/NOKIA_COM_1/Microsites/BetaLabs/applications/apps/NokiaDeviceStatusInstaller-1.1.2.exe
Compatibility:
Supported devices: tested with all Nokia Eseries devices. Should work with all Nokia devices based on S60 3rd Edition.
System requirements: PC with Windows XP SP2 or Windows Vista (32 or 64 bit, each). Nokia PC Suite (6.84 or newer) or Nokia Nseries PC Suite needs to be installed on your PC.
Source: http://www.nokia.com/A4596393
Does it tell you any battery info. I have been after something that does that for ages (remaining charge as a percentage would be ideal)
