How can I make the N95 show the SIM contacts by default when I open Contacts?
Making N95 show SIM contacts by default?
I don't think you can. The manual shows that if you want to make calls to contacts on your SIM card, you must first copy them across.
However it also says, Press , and select Contacts > Options > SIM
contacts > SIM directory to see the names and numbers
stored on the SIM card. In the SIM directory you can add,
edit, or copy numbers to contacts, and you can make calls.
Hope this is clear (as mud).
chrsfrwll wrote:I don't think you can. The manual shows that if you want to make calls to contacts on your SIM card, you must first copy them across.However it also says, Press , and select Contacts > Options > SIM
edit, or copy numbers to contacts, and you can make calls.Hope this is clear (as mud).
That is really, really annoying.
I don't like having my contacts on the phone as I switch SIMs a lot :/ I've also realized that when sending a text and choosing a recipient, you can only select numbers on your phone. Can't believe Nokia have chosen to do things this way.
Cheers for your reply mate.
you can put whatever number you want in. Go to new text, open it and type the number you want to send your text too. If you get the ABC just hold down the # key to change it to numbers.
Hope this helps.
DJ Mike wrote:you can put whatever number you want in. Go to new text, open it and type the number you want to send your text too. If you get the ABC just hold down the # key to change it to numbers.Hope this helps.
No, I mean write a text message, go to Contacts and nothing shows up unless you have numbers on the phone. You can't even view the SIM contacts to choose from :/
King Mustard wrote:That is really, really annoying.I don't like having my contacts on the phone as I switch SIMs a lot :/ I've also realized that when sending a text and choosing a recipient, you can only select numbers on your phone. Can't believe Nokia have chosen to do things this way.
Woouldent this be benificial to you then the numbers would be there regardless of sim or do you mean phones?
Unplugged wrote:Woouldent this be benificial to you then the numbers would be there regardless of sim or do you mean phones?
Since I swap phones a lot, I don't really want my contacts stored on each Nokia I come across :/
Ah ok that would make more sence 😊
My understanding is this behavoir is happening a lot more in phones now not just nokia 😞 most phone lets you store a wealth of information and simcards STILL only provide basic name / phone number.
I also find this REALLY annoying. As Unplugged mentioned I think it was because you can hold more information on the phone than a sim card about each contact. All series 40 phones have this ability its just one of those things that S60 team lag behind again with, rather than all nokia phones.
davesmith wrote:I also find this REALLY annoying. As Unplugged mentioned I think it was because you can hold more information on the phone than a sim card about each contact. All series 40 phones have this ability its just one of those things that S60 team lag behind again with, rather than all nokia phones.
I am happy with what the SIM can hold. They can hold a contact name and various numbers per contact. That suits me nicely.
