Icons not appearing
2 replies · 1,512 views · Started 10 October 2007
On my 6680 icons on the display screen are not appearing i had a virus in my phone then i got my phone flashed everything was deleted then when i went to settings then to standby display the option of activating icon is not there can you tell me a software which will give me icons on my mobile screen or how to get back those icons please tell me
What kind of icons? ROM icons? From phone firmware? Just try an upgrade and should be solved. Icons from software installation? You should install again that same software.
