Nokia N73 Software version 4.0735.3.0.2 / 4.0736.3.2.1 released - 9 October 2007
This software version includes Nokia Maps 1.0 (edition 1.2) for use with Bluetooth GPS devices.
This release also includes updates to the Music Library and music downloads, and performance improvements to SMS and device application installers.
* Most of the Bluetooth problems seems to be solved!
* Nokia Maps standard installed now
This update is available via Nokia Software Updater!
Hello did you notice anything about Speed? Ram Management? Able to close Music/Menu? Camera improvements? anything???
Installed this firmware last night. Only problem I had was that when I inserted my memory card 8 of my apps. would not re-install automatically as they had always done in the past. Came up with 'file corrupted' ?. Have installed new firmware five times so far on this phone & it's never happened before. I decided to format my card & re-install everything.
Other than that everything is working ok. All my bluetooth devices were recognized. Phone start-up seems quicker & generally faster all round.
Handy Taskman also loaded at startup, which it did'nt on last firmware.
Will keep you updated.
I had a problem with some apps, Just set the date back 6months and installed then they worked.
How do you put stuff in your handy taskman?
[SIZE="4"][B][B][FONT="Arial Narrow"][B]Dear friends,
I need some valuable information about updating my N73 ME. I have only computer during my work and I cant install the NSU over there because i have no admin right. I heard there are someways to update the software without NSU or even without a internet connection. I have a good speed internet connection. Please advise me.
thanks,
ROBERT[/FONT][/B][/B][/B][/SIZE]
Updated last night and I can confirm that the Bluetooth issue has been resolved. That's all well and good, but I went and bought a new GPS receiver because of that issue !! LOL
Still, the missus can have that to use with her 6680 and then when she inherits my N73 (after I get the N95 8GB) she can still use the BT77 and I can benefit from the 44 channel goodness of my BT441 Holox.
As for the new firmware, once I've checked all my other apps, I'll be able to give a better, more informed opinion, but at this early stage, all seems well, which is a vast improvement over last time's debacle !!!
does the problem of camera solve? i mean the blue haze. low lights image prob..:con?
