Is there any way to change the voicemail number which is used when the phone tells you that you have a new voicemail? Failing that can you change the quick dial number for the "1" key?
No. Is the 1 key!
If you're just trying to change the number the phone uses to dial voicemail (either by holding the 1 key or when it tells you've a voicemail) then I think it's set in Menu->Tools->Voice mail->Options->Change Number.
