9210 and GPRS it can work read below
1 replies · 2,769 views · Started 24 February 2002
Well the answer to the queqtion is yes you can
and no you cant
I finally managed to surf for 20 mins at gprs speeds the 9210 comes alive at last
ER6 site is readable clicking on liens
brings up the new page quickly and downloading is fast didnt get time to try up loads
You can visit sites that load at acceptable speeds . Its pity realplayer for the nokia wont stream
The ir connection obviosly limits the speed
but its a lot faster than a simple gsm connect
Any way after 20 mins ......( 5 days fiddleing about till 2 AM for 20 mins then 5 days reinstall ...... I wont be trying again ...this week...)
It crashed and since then I cant get it up and running so I am slowly reinstalling from scratch Yawn Yawn
It most probbably crashed from messed up files as i tryed so many different combinitations before getting the two phones to talk together and reinstalled and uninstalled a host of software( that I will not name here untill I find out if a particular piece of software was at fault or not )
I was also useing the IR link not a strong point on the 9110 and still weak on the 9210 the only way out is still the good old Remove battery ....
anyone know a way to backup and reinstall apart from the nokia way
now my question whats the best way to go about a total rebuild on the 9210
and second q how to save that as a starting point and not go thru it all each time
(this is the third time once on sys upgrade / once on "trying to get a max of free ram on the c drive)
pc suite backs up and restores data files ok but the rest it seems to be pot luck
and to back up data files I can do that a lot quicker and safely to the card or a hard drive on my pc
heres some ideas for useful programmes
a prog that will free up the max space on c safely by moveing files that can be to d
a progra to save to card or hard disk
data files
programme files
systemfiles
parameter files (all those so cleverly hidden menus in menus that you take hours discovering and configering then promptly forget how you got to them what they do and what you did etc�)
etc etc
Thanks for the tips old chap.
It's always good when someone paves the way and finds the landmines before others walk over them!
