Syncable Notes application?
2 replies · 7,778 views · Started 11 October 2007
I am looking for an app which will allow me to make notes on a PC and on an
N73 and sync them back and forth.
I use the regular Nokia PC Suite (6.81.13.0) to sync with Lotus Notes and it works well enough for Calendar and Todo, but I want to keep other small records in both environments. I don't believe PC Suite syncs the Symbian Notes app.
Any suggestions? I have Outlook as well and use Companionlink's DoubleLook to move stuff between Outlook and Notes, to sync with a Windows Mobile PDA, so a link with Outlook would be fine. Or anything...
😊 I don't know about sync. , but when you like to make your note-files visible in Filemanager ( C or E) , try a small application called LightNotepad - www.petnetti.net/lightnotepad - The website is in Finnish & English . Copy & Paste your Notes to Lightnotepad . It's a stable application , however with some limitations , like max. 200kB editing .
😊 May help also in syncing . Regards jApi NL
