Does anybody know if there is an emulator or some other application that will let me run an S60 2nd edition application on an N95.
Run S60 2nd ed app on N95
Simple answer.... no. You'll either have to persuade the developer to redo it for S60 3rd Ed or find something similar. What program is it?
I bought an iTech bluetooth virtual keyboard that said on the website it was compatible with Symbian S60 phones. It wasn't till I got it that I realised it was only compatible with S60 2nd edition.
iTech say they don't have software for the N95 and can't tell me if they will in the future. Very frustrating. Should have read the fine print before purchasing.
Heh, I just sold mine on eBay for £60 😛
Have you tired installing one of the nokia bluetooth keyboard drivers?
http://europe.nokia.com/A4144291
Also, it might be worth poking through this guide to see if it will work on the default settings:
http://www.allaboutsymbian.com/features/item/How_to_Use_a_Bluetooth_keyboard_with_your_smartphone.php
Tom
Thanks for the tips.
There is an interesting post on the subject at all about symbian.
(i'm not able to post links)
