followed all the installation steps and cant get it to work.when i click the icon it just does nothing.must be something minor but annoying all the same.any advice guys?
quake
Did you also install the Symbian runtime? It's needed for the game. The file pips 60 wp.sis
yeah.does it matter that i installed everything to the phone and not the memory card?
no, the proram is fine in the phone memory. Next question, have you installed the quake ID1 files? Best on the mem card given the size.
would that be the pak file?if not could you tell me where to get it from?
if anyone has the time a quick easy to follow set of instructions would be great
Yes, the pak files. Basically the instructions are as per the developers website
1. Find a suitable datafile - you can get a shareware one here http://www.fileshack.com/file.x?fid=114
2. Create "quake1" folder to the root of your memorycard, E:/quake1/
3a. If you have the full version, just copy the "ID1" directory to "quake1" directory.
3b. If you have only a shareware .pak file, create "ID1" folder to "quake1" directory and copy the shareware pak-file there. (for me, that is E:/quake1/ID1/pak0.pak)
4. If you want to have cdaudio aswell, create "cdaudio" folder to the "quake1" folder. Then put the audio files as .mp3 to the "cdaudio" folder, remember to rename the files from 1.mp3 throught 10.mp3. I don't know what bitrate is the best, but I have used 256kbps and it has impact of 0.1 fps to the performance. If you do not have the required audio files, the background music is just not played.
5. install the Symbian P.I.P.S. c-runtime library (pips60wp.sis)
6. install the suitable version of quake. for the N95,
quake_v102_armv6_fpu.sisx
That should be it.
cheers mate only i cant download from file shack as i have already registered apparently and dont have password or anything.could you mail the file to me any cahnce? [email][email protected][/email]. sorry to be a pain.cheers
