I saw an article that Steve wrote about changing the applications that you could initiate within the active standby screen, but it was for the E90. Does anyone know if you can change the apps. on the 6120c, and if so how is it done?
Active Standby for the 6120c
I think this is what you are after:
Press the Menu Key, go to Setting Folder then open Phone Sett.
Select General>Personalisation>Standby Mode
From here there are Shortcuts (for the 2 hot keys) and Active Standby Apps to change the apps on the Active Standby Screen.
I see I had to have active standby on before I could select the option to change the icons. Thanks for the help!!
