has anyone found a good bluetooth print adapter to connect to your inkjet or laser printer to print from the n95?
bluetooth print adapter -any success?
just buy a network printer, be it wireless or wired, as soon as you connect it to your home wifi network, you should be able to print to it from n95 via wifi.
i got a very good HP Photosmart 2575 for only �45 delivered (back up to �100+ now though) got it via www.hotukdeals.com
Agreed. Photosmart 6180 here and it works perfectly. Very impressed 😊
GazP wrote:just buy a network printer, be it wireless or wired, as soon as you connect it to your home wifi network, you should be able to print to it from n95 via wifi.i got a very good HP Photosmart 2575 for only �45 delivered (back up to �100+ now though) got it via www.hotukdeals.com
How did you get it to "see" the wifi printer?
My N95 connects to the wifi internet at my house fine. And my printer is on the same wifi, but my N95 doesn't "see" the printer, can you give me any advise on how you got it to connect.
I have tried searching for it but to no avail!
http://www.allaboutsymbian.com/forum//forum/thread/64369/&highlight=printer
check my response to your last thread!!! 🙄
