Music via BT on w950i ??
1 replies · 2,405 views · Started 13 October 2007
Cant seem to play music over bluetooth on my w950i?
the option is under more/settings/transfer sound ??
but bluetooth is not one of the options availble -- yes my bt headset is connected.
(I can make calls on it) The only options are speaker/wired headset (when its connected)
The BT headset is not sony branded - does that matter?
Im using a nokia HS26w headset.
Also while the BT headset is connected the ringtone is just the standard bring bring and not the custom ringtone? any way to change that?
