remove damaged themes?
1 replies · 2,101 views · Started 13 October 2007
I installed some custom themes on my phone from mobile9. After a firmware update they no longer work and I get a theme damaged notification. Also when I try to uninstall them from the phone nothing works. Can anyone tell me how to completly remove those themes from my phone?
weren't the themes set back to default when you updated the f/w? How did the themes appear again? Did you do a backup and restore them from there?
check this page out tho... as it gives you the back door method to delete dodgy apps. (themes) 😃
