i have bought a p990i recently.
but i can't use it's WLAN. when i scan for available networks, a massege appears saying " no access points found"(!!!). i know the network exists, because i can access it through laptops. :con?
does anyone knows what the problem is..
the network is a kind of VPN.
you really think that's enough info to get a useful answer?
The reason for this is that probably the SSID (name of the wireless network) broadcast is disabled on the wireless router for security reasons. Find the SSID of the wireless network with the admin. and check if WEP / WPA encryption is enabled. You will also require the WEP / WPA key. Then manually configure the WLAN on the P990i.
Cheers !:icon14:
