Yes i had a new N95 deleivered a few days ago through the insurance.
I backed up the Music files, picture files, but WHY did i not back up the contacts.
Now how do I move the contacts from either my Microsoft outlook contacts, or my outlook express contacts, OR BOTH !!!! pref my outlook contacts.
I have tried to create a PSV export and drag and drop however this is not working.
Is there an easy and simple way, PS I am using the N95 PC suite.
Many Thanks
Andrew Palmer :icon14:
Hmm... is it a recent version of PC suite?
As soon as I connect my n95, it automatically synchronises the contacts between Outlook and the n95.
Clicking the "synchronise" button on PC suite doesn't help?
Use the "synchronise" feature of Nokia PC Suite. Go to settings, and say you want to synchronise from PC to Phone (normally you would leave it at auto, but it may have to be "coerced" into going from PC to phone).
Job done!
All sorted through the Nokia PC Suite - Sycn section. Thanks you
Another problem solved.
