N95 Replacement Speaker Required
2 replies · 3,092 views · Started 15 October 2007
Hello Chaps,
My N95 speaker has gone really distoreted and Crackly, Ive tried poking thru the holes to push it back in.
Now its gone quiter and still is crackly, Ill probably try taking the metal plate off and see inside of speaker.
But i need to know where i can buy a replacement speaker for it just incase i completely screw it.
Ive opened phone couple of times so no warranty.
Moy
The best you should do to don't try to fix your $800 phone at home. Bring it to the closest nokia service point. They can order the parts.
Good luck!
swingerman wrote:The best you should do to don't try to fix your $800 phone at home. Bring it to the closest nokia service point. They can order the parts.
Good luck!
Try taking it their maybe they wont notice you have opened it.
