Themes
8 replies · 3,014 views · Started 15 October 2007
i am trying to get rid of themes that i dont use anymore but cant seem to find them.they dont show up on the app manager, can someone tell me the location of them on the phones directory.thanks
Here is how to delete themes that aren't in the app manager
*This only works for themes on memory/sd cards*
You need to hook up your N73/N93/N95 or what ever you have to your PC via the USB and access the data transfer/mass storage mode,and you need to make sure your file explorer can view hidden folders.
You'll find the theme filesin a folder named 'Private',in this folder are lots of other folders.Go to the folder named '10207114' and then eneter the folder inside called 'Import'
In here are all the themes on your sd card.
You have to open every folder and then look in the skn folder to find the name of the theme as the folders are named by numbers and not the theme itself,if the PC doesn't allow you to open the file then choose to open it with Notepad,then scroll across until you see the name of the theme and usually it'll say the creators name too.
Once you know it's the theme you want to delete then you have to delete the whole folder including including the mbm,mif,ini and skn folders.
Job done
yeah, do a bit of a search and you should fine plenty of methods for clearing themes.
kontraband wrote:yeah, do a bit of a search and you should fine plenty of methods for clearing themes.
:con? isn't there a clear enough explanation on how to delete themes that aren't in the app manager above your post?
mr g wrote::con? isn't there a clear enough explanation on how to delete themes that aren't in the app manager above your post?
why are you quoting me?? Your comment clearly says *This only works for themes on memory/sd cards*, yet the poster was talking about phone memory?
kontraband wrote:why are you quoting me?? Your comment clearly says *This only works for themes on memory/sd cards*, yet the poster was talking about phone memory?
I apologise,i didn't see that part :redface: :icon14:
