@waveydave
I don't think anyone is suggesting we shouldn't use the N95 to the max? But when comparing standby time, we must be fair and compare under the same conditions. So when comparing to a standard phone, the N95 must also be used as a standard phone. We could also measure the standby time when using it as MP3 player or GPS navigator, but then it should either be done as that option alone, or a fixed time set aside for each option.
@dez_borders
Thanks for the kind words. As a follow up, here's the result of my standby test, which I concluded just minutes ago.
Everyone knows that the first battery indicator bar lasts the longest. I was under the impression that once that bar is gone, the rest goes very quickly. In reality there's still a LOT of standby time left...
First I 'prepped' the N95 for max battery performance. For example the 3-branded Danish settings keep a constant logon to the data network, so I have debranded my device. Next everything 'auto' had to go. No auto update of emails, weather or whatever. During this test that was all done manually and only when needed. I also used the standard screensaver, even though I like the Handy Weather a lot. 3G network with full bars on the indicator most of the time.
The test ran for five days, so even though I refrained from using the nice extras on this phone, I still used email, weather updates, sms'ing and made a few short phonecalls.
The result:
1 bar lasted 26 hours = 1/3 of total
2 bar 7 hours
3 bar 14 hours
4 bar 9 hours
5 bar 4 hours
6 bar 2 hours
7 and last bar lasted for 13 hours. During this time a warning popped up from time to time, indicating that the battery was low.
I have found no logic in the standby time of each bar. I wonder if the result would be comparable for each bar if tested again? I am not about to do it, though, because it takes a lot of resources to keep checking the meter for such a long period.
All in all this adds up to 75 hours of standby time of which 49 hours is AFTER the first bar is gone. This is so much more than I expected and means that I no longer have to panic if the first bar drops at 6pm, which is actually nice to know 😊
