Can you sugest a photo organiser prog
3 replies · 2,685 views · Started 15 October 2007
Hi
As Nokia still havn't got the photo organising thing right.
Whilst there is the option to put the photos in an album, thats about as far as it goes, can anybody suggest a good quality photo organiser program,,,,ps don't mind paying for it...
Cheers
have a look at adnota on S60.com
theres probably others on there too...
I guess it depends what organising features you're after, really.
I use Resco Photo Viewer myself, but all I do is view photos (it's much better than the default gallery application, as it auto-rotates photos to best fill the screen) and move them between folders.
Well i used to have a program from Resco, but that was for my xda.
It had two parts, one for the main album creating and image manipulation (including auto resize)
and one on the xda for viewing the albums.
The photo viewer you're sugesting doesn't quite do what i'm looking for....
Cheers
