I am thinking about ordering a P800 in about 12 hours (bank transfer just needs my auth). I am just hearing so many problems with the phone, so I am wondering is it really worth it? I love the phone design and features but I live in Minneapolis, Mn and would be importing it from www.mobilefly.com for a total of $871 after shipping and all. So what do all you users think?
Shane
Should I or should I not...
Let me reassure you that you are not paying way too much.
Basically, the only thing Ii can say is.
Do you need it ?
If you can answer this question( im assumin u know most of its major specs)..
then go ahead and order it 😃
Dont forget, ur mobile phone service provider has to have a GSM SIM Card chip enabled service 😃
Well yes, I have been without my PDA for about 3 days and i AM DYING. I would love the intergration and size. I have t-mobile and it will work fine. The onlything now are the problems so serious that is is not worth it at this time or at all?
Well, all I can say is that it's the sweetest investment I've made in a while! 😉 I've had my P800 for almost a week and I've utilized nearly every feature of it: MP3, MP4, bluetooth, infrared, USB sync, GPRS...you name it! So far, there's little complaint to be said. It's definitely worth every penny I spent and more.
What kind of problems are you hearing/getting anyway?
yes you should really get it...the problems are little and few and should be fixed with a firmware upgrade, the problems will not cause you any harm......
Well thank you all for the help on this. I will go through with the order shortly. I will be back to post as soon as I get it also!! Oh and if you anyone is looking for screen protectors Brando has them http://shop.brando.com.hk/screenprotector.php . I get my screen protectors here all the time. THanks Again Shane
