In Nokia 6120:
* How do you lower the volume in games/programs? Now I always get maximum sound and music volume, and it's way too much.
- Use headphones with analog volume control.
* How to not make the phone freeze halv a second every time a sound effect is played in most games? Makes most games unplayable.
- No reply yet.
* How to fast forward music in music player?
- Hold next button.
* How to remove installed broken games that doesn't want to be removed?
- Ny reply yet!
* Is larger than 2gb microSD supported?
- 4 works, but 6 and 8?
* Is there a way to set it to warn when exiting a game/program? It's so easy to accidently press the exit button.
- No reply yet.
* What is the difference between 6120 and 6121?
- No reply yet.
I am currently using a 4GB micro SD card in my 6120c with no problems.
posting this from a 6120. Had to turn off predictive text to type the numbers as they were activating shortcuts on the site!
Anyway, usually in media players when there isn't a fast forward button holding the next track button works. Give it a go, i can't as i don't have any music on here 😊
What games are giving you audio problems, are they java games or series60 specific games?
petersonwd wrote:I am currently using a 4GB micro SD card in my 6120c with no problems.
Thanks! Anyone tried 6 or 8gb yet?
lightbulb wrote:Anyway, usually in media players when there isn't a fast forward button holding the next track button works. What games are giving you audio problems, are they java games or series60 specific games?
Holding button works. Thanks!
They are installed java games. Most of the do not have internal volume settings but just on/off. I think I will buy a 2.5->3.5 converter and use headphones with analog volume control. Max volume is very very seldom prefered.
as far as i've read on wikipedia..
6120 is compatible with the 850 gsm band
while 6121 is compatible with 900
