I cant connect to my 7650
In my 7650 require passcode but i cant change to ABC mode (its default 123 mode) so it's allway not be connected
Abe USB bluetooth dongle with XP
I really dont get what is the issue here? You cant pair you 7650 with you PC? Read the manual,i think that you have to enter the same password on the on the 7650 and on the PC.
Then why not use the same numerical passcode for both devices??
Just a thought...
:roll:
Yes,that was the original idea but i'm not sure if that is duykhang's problem because his quetion was kind of cryptic to me 😃
you are right, i have read manual of 7650 and input passcode is numberic only. So my problem isnt passcode, but have you got any hint to set in property of BT adapter to run in WIN XP SP1
enter the passcode on your 7650, then your computer will ask you to enter the same passcode.
