E61i Switch Profiles with # Key?
6 replies · 3,915 views · Started 16 October 2007
i recently changed my E61 for an E61i and have not been able to sort out 2 small problems.
1. I am unable to switch between General/Silent profiles using the # key which i though you could do on most S60's these days? When i try it just types lots of #'s instead. :frown:
2. The Email Key opens up the Nokia for Business web page when pressed, dispite having it set to open a specified mailbox. When held down it DOES open a new email, but I have been unable to get it to open my default mailbox. No idea why it would do this, but seems quite a common problem.
If anyone could shed some light on the above issues I would be very grateful 😃
Apart from that its a great device :icon14:
i've heard others of similar complaints but no solution offered so far, sorry. mine is working fine though.
thanks for your relpies.
I guess ill have to look out for some firmware updates in the future.
Muy current version is: 1.0633.22.05 dated: 15.02.07
just tried with mine...
if I hold the Email it'll create a new mail.
if I Fn-# it'll just repeat the #
maybe u got a unstable keypad?
