Need some support during sync my p990i with outlook
1- If i have more then mobile in any of the contact it sync only 1 mobile number in the outlook, how can i sysnc all of them.
thx
thx
Mine works fine....what version of outlook are you using? How are you synching? over WiFi or using Cable? What version of sony ericsson software are you using?:con?
