Strange Speaker Issue
3 replies · 2,275 views · Started 18 October 2007
The beeping sound the phone makes when you press keys for example, has changed!
It sounds 'broken'. Its the only way I can explain it, more tinny then it used to be.
Oddly though, all other sounds seem to be ok and both speakers appear to be working fine. The problem is just with the key press tone. Does it work off different speaker?
Also I thought it made a sound when closing the slider when it auto locks? It doesn't do that anymore either!
Has anyone else had this problem?
Nope.
Its also buzzing in call, in the ear speaker. However I blew into the speaker and it seems to be alright again now. Maybe dust?
I notice a lot of hissing on all audio the phone produces - I can hear it on headset as well as using the earpiece, so it's not related to any particular output hardware.
