Nokia N95 Please Help!!
7 replies · 1,849 views · Started 18 October 2007
Ok i have had my Nokia n95 for about 6months but i do not not very much about s60 phones.
I would like to know what programs i can use to use msn on my nokia n95 and how much would they cost to use them? I was hoping to be able to use msn for free as my girlfriend uses it on her nokia 6288 but thats on 3g mine is on a vodaphone contract. I was also wondering if there was any other software people would recommend.
What is the latest good firmware for uk nokia n95's?
Also my GPS doesnt seem to work when i go to maps to find where i am on the map my screen zooms in but then stays white although i have a gps connection? Is there a way to get google maps and is it any good?
try Fring!
will cover MSN, ICQ, SIP, GTALK and the software is free... (its in beta mode at the moment, but plenty of users)
Dont use maps so cant help on that one.
V. 12.0.0.013 is the latest fw....
Hyuukai wrote:I would like to know what programs i can use to use msn on my nokia n95 and how much would they cost to use them? I was hoping to be able to use msn for free as my girlfriend uses it on her nokia 6288 but thats on 3g mine is on a vodaphone contract. I was also wondering if there was any other software people would recommend.
If you search about the forum you will find a s60 version of Windows Live Messenger which you can install. Its prob the best one your going to find and prob the best version of a mobile msn client ive seen. As for data usage if you dont send files using it or voice messages its not that data intensive.
Hyuukai wrote:What is the latest good firmware for uk nokia n95's?
v12
Hyuukai wrote:Also my GPS doesnt seem to work when i go to maps to find where i am on the map my screen zooms in but then stays white although i have a gps connection? Is there a way to get google maps and is it any good?
Do you have an Internet Connection? The Maps download over GPRS unless you use Nokia Maps Loader to stick the UK maps on a memory card ( which will take about 120 or so MB )
if you use wifi is doesnt cost with Fring,
but if you download from Download! the MSN live client thats free for 30 days then theres a charge...
I mean is there any charge in using it like a data charge or somthing? :S
whether or not theres a charge for data depends on your phone contract...
Fring doesnt charge you to use it no matter how much data you send thru it... MSN Live only charges you for the program after 30 days but again, doesnt charge for the data used.
The data is charged according to your contract.
