hi just put a 3 sim in my unlocked and unbranded n95, i am 99% happy but as you will be aware all the 3 stuff has gone. not to worry.
all i need from one of you dudes is the "my three" web link so i can save it as a favourite and visit it via wlan etc
so if anyone has it so i can check my balance, downloads etc etc would be most grateful
cheers
wayne
depends which country you live in..
i got similar to mobile.three.com/portal
Hi
I answered just this very question in the last 3 or 4 days
Can't remember what the answer was, but if you search and scan the last couple of days posts you should find it no problem
Mate i had the same problem as you.
Solution:
What you'll need is to change the Product code on your N95 (search the forum lot's of how to guides on here) to a 3UK (0546553 code i used) then go and load up Nokia PC suite and do a up software date on the phone
NPC will look of any 3 updates available and add all the 3 settings
If you love the phone before just want and see what you think after this!!!!!
Try this guide?
http://clear-nokia.blogspot.com/2007/05/nokia-n95-debranding-guide.html
Cheers Mate
My Only Prob Is Because 12.0.013 Software Is Crap Gone To Product Code Change To Make It Apac 12.0.014 So Now I Cannot Back Date But Got Rid Of Buggy Software, 12.0.014 Is Tops Believe Me.
No Worries Though Wife Leaves 3 Next Month And Will Maybe Try Voda Doing Cracking 12 Month Deal On Normal N95
Cheers
Wayne
