Where is the calendar data held?
1 replies · 2,039 views · Started 19 October 2007
Can anyone tell me where the calendar data is actually held and in what format?
I have been looking for a calendar app which is capable of exporting to a standard (eg .vcs) format but without success. All the apps clearly use the same base data. I might write a utility to do the export I want, but I need to know the answer to the above before I start.
I would be grateful for any pointers.
bogzab wrote:I might write a utility to do the export I want, but I need to know the answer to the above before I start.
If you use Python you could use the appropriate API calls without having to know where the data is stored.
