Hey!
Has anyone had any problem on auto focus in N95? The camera simply won't auto focus from at least 2 metres away.
I have been hearing that when you shake the camera while you half press the button, it will auto focus. This method seems to work for me for a couple of times.
Any suggestions? Thanks!
You need to send it back to nokia for repair or take it to your nearest Nokia Service centre, there seems to a flaws inherent some N95's. I had this problem with my first N95 in the end Nokia swapped the phone for a new one.. Now autofocus works on just about anything outdoors indoors and at most distances.
Thanks!
What firmware version are you using?
update the firmweare first, yep.
Once that is done, and if it still doesnt work, chick it at Nokia's. These firmware updates can really help with some bugs...
voodoomox wrote:Thanks!What firmware version are you using?
V11. something but it isnt software related its a hardware issue.
Hey,
Mina has suffered with this problem to. Just today I have dropped it off at my local NSC for them to repair.
Will let you know the outcome.
Hey All,
Camera module was replaced in the end and all works fine now with focusing.
thanks guys, i'm currently using v12.0.013, so i guess i will need to call nokia
:frown:
i've just upgraded my firmware to v20.0.0.15 and the camera improved sooo much 😃
