Nokia N95 usefull apps and other questions...
2 replies · 2,758 views · Started 20 October 2007
Just got my Nokia N95 today after upgrading from a Windows mobile Orange M3100.
Just purchased epocware's Handy Safe for use with my new phone as I always used to use eWallet on my M3100. Is this a good alternative?
Also, I am after a decent alarm clock as the built in one seems too restrictive for me.
What would you recommend?
Are they reliable?
I noticed that epocware do one, is this any good?
Also, any other usefull apps out there to make more use of my N95?
Few more questions:-
Is the camera 5 megapixel by default as I heard that you need extra software purchasing to give 5 mega pixels. Is this the case?
Also, is there a way to get the internal GPs working with TomTom?
Mark
mdavenport wrote:epocware's Handy Safe for use with my new phone as I always used to use eWallet on my M3100. Is this a good alternative?
Yes. I use it, also after ewallet. Best bit, it will read in ewallet files.
mdavenport wrote:Also, I am after a decent alarm clock as the built in one seems too restrictive for me.
I've never found a commercial alarm app that offered more than the built in version (for what I needed an alarm clock for).
mdavenport wrote:Also, any other usefull apps out there to make more use of my N95?
Loads. You'll need to do a search and read the threads. Also, it depends upon what you consider useful, but to give you an idea, I have Handy Weather, HandySafe, Papyrus, Agile Messenger, Truphone, Navicore, Profimail, Quake, Coreplayer, MobileDesktop, RescoViewer, MobiReader, VirtualPool, SIC! FTP, SkyAnytime, Active Notes, OperaMini (the list goes on)
Yes, though you can downgrade it to make smaller files, through the settings
mdavenport wrote:Also, is there a way to get the internal GPs working with TomTom?
No, not yet. Read the various threads on the subject.
Thanks for this information. I am now using Handy Safe and have imported my eWallet file and works a treat.
I also use ListPro on my old SPV M3100. Is there an alternativ for this that can import ListPro files?
Mark
