The ans. for How to make subfolders in menu
0 replies · 1,051 views · Started 21 October 2007
Wirelessly posted (Nokia6681/2.0 (5.37.01) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Here is the great news for symbian phone lovers(s60) that "How to make subfolders in menu.So following is the way to do it.First create the folder(or keep the old folder)which you want to put to some other folder.For e.g.If you want to put 'java' folder in 'games' folder then first move the java folder to first place(the place which opens by key 1 in menu or the topmost of leftside of the menu).Now you may have noticed that
when you install or uninstall a program the pointer returns to the topmost of the menu.That is the fact when you put the folder(java in my e.g.)in the first place.Then either install or uninstall something and when the message 'installation' or 'removing' appears then quickly press the menu key(it should be quick)place your pointer on any non-folder icon(gallery or contacts or any other program)and press options.Don't do anything for sometime.In the background when you realize that pointer had returned to its original position then click move to folder and in this way the folder which you had placed in your first place could easily be moved to any other folder....Works on Nokia s60
Best wishes....DuggaAAQIB
