tomtom 6120
2 replies · 6,018 views · Started 21 October 2007
i know its been asked before
i tried to install tomtom v6 to my 6120 and it wont let me install does anyone know where i can get it to make it work!???
i dont need the maps
if u have a 'card' version, which utilizes mini/micro sd, follow the instructions, then insert the card and installation will begin and finish in a few minutes.
normally u dont have to turn off the phone. but to be on the safe side, i turned off my phone, inserted the card, then turned on the phone and installation began.
if not, a firmware flash will fix the problem. once nokia maps screwed up my phone and nothing was installing, then flashed my phone and tomtom installation was successful.
