hey, i was just wondering if anyone knew of an app that sits on the desktop and keeps track of things like text messages and minutes and even data?
maybe with the functionality to put your tariff details in and then it to display how many minutes/txts you have left or extra you have used. and then reset its self at a given date (when you get billed)
maybe even with the ability to know the difference between wifi data usage and gprs.
anyone know if anything like this exsists? if not whos going to develope this 😉 i would pay for it!
RTO wrote:hey, i was just wondering if anyone knew of an app that sits on the desktop and keeps track of things like text messages and minutes and even data?maybe with the functionality to put your tariff details in and then it to display how many minutes/txts you have left or extra you have used. and then reset its self at a given date (when you get billed)
I don't believe the app you describe exists.
However the built in Log application provides about 75% of the required functionality you want.
You can track data usage, incoming and outgoing voice calls, etc.
You can (manually) reset the counters on your monthly billing date so you should have an accurate record of data and voice usage.
The only thing it doesn't record in number of SMS you send or receive.
Sounds like it should be quite easy to implement for someone with sweet S60 skills
