Sometime the media key (the one with 4 points on the front right of the N95) on my N95 becomes inrespondive when I press it and only re-activatesif I swith the phone on and off. Does anyone else have this problem or can offer any solution?
Unresponsive media key
It's a known bug in the firmware, related to a repeating alarm on workdays.
A search of this forum will reveal more details.
R
yeap its a known bug the old software, something to do with when a Repeating alarm is set.
try deleting your alarms and see if that sorts it/stops it coming back?
if so, you either want to not set alarms again, or upgrade firmware
GazP wrote:yeap its a known bug the old software, something to do with when a Repeating alarm is set.try deleting your alarms and see if that sorts it/stops it coming back?
Thanks, but I can't accept not using the alarm feature beacuse of a bug, it is quite an unacceptable failing of the N95. Anyway, I don't understand what firmware is (is the equivalent of an operating system?). If so, how do I check my version and how do I know if I should update it, does it wipe everything from the phone?! And will it solve the unresponsive media key?
nickmon wrote:Thanks, but I can't accept not using the alarm feature beacuse of a bug, it is quite an unacceptable failing of the N95. Anyway, I don't understand what firmware is (is the equivalent of an operating system?). If so, how do I check my version and how do I know if I should update it, does it wipe everything from the phone?! And will it solve the unresponsive media key?
You can check your Firmware version by hitting *#0000# that will give your version. You can use Nokia Software Updater to upgrade the firmware.
can someone point me in the direction of getting that bug! that multimedia key is as usefull as a football bat
snuge wrote:can someone point me in the direction of getting that bug! that multimedia key is as usefull as a football bat
just add a few quick alarms and it should stop. Or if you want to use the key again remove them all.
Ah, I have that problem and I never even noticed.. shows how useful that key is. It is extremely bizarre, though.. there's no obvious connection at all between repeating alarms and the multimedia menu.
