Converting movie to 800x352 ?
6 replies · 7,803 views · Started 23 October 2007
Hello,
I am struggling with converting my DVD`s to a format that my E90 understands. Either the picture is there, but no sound. Or no picture, but only sound.
I am using ffmpegx for macos x. Would be nice if someone with mac could tell me what settings I should use? Or is there a better converting program for macos x?
Regards,
Amix
I am afraid that this not going to solve your problem, but for the 800x352 pixel resolution the best to use is mediacoder, a free tool.
Actually I have the e90 setting. Let me know if you need it.
The problem is that it is for PC.
Here the answer:
nokia-e90(dot)blogspot(dot)com
You also can find many movie samples optimized for E90 there.
When you want to convert a DVD to a movie for the E90, you can use Handbrake, which is a free program. Be shure to use the MPEG4/AAC option, and ffmpeg for the encoder. When you use xvid for the encoding, you get either no video, or no sound.
When you want to convert an existing movie ( .mov, .avi, .wmv... ) to a movie for the E90, you can use VisualHub to turn them into MP4 files.
Handbrake:
http://handbrake.m0k.org/
VisualHub:
http://www.techspansion.com/visualhub/
If you need help using these applications, feel free to contact me.
