London Underground Map
6 replies · 3,169 views · Started 23 October 2007
Anyone know of a good interactive tube map for the london underground.
Preferable one that can plan a route etc wembley to covent garden and telling you where to change etc.., failing that a simple app that is scrollable.
I've downloaded metro and this does the job from a non-graphical view, however is there a free London underground map out there compatible with the N95.
I didn't want to spend as much as Visual.IT's Tube2 as I don't go London often enough.
Just save a copy of the London underground map downloaded from the web 😊
I use a JPEG file of the map. Even though the PDF worked it was very slow to zoom in .
I agree I use the pdf from the london underground website. You can at least search by name with it. There is no point having a java app that does this anymore on S60 devices
