P990i camera (doesn't save the pics)
3 replies · 4,008 views · Started 25 October 2007
Hey Guys I have a P990i and all of the sudden it stopped saving the pics I capture. Very odd
It captures but doesn't save
You guys had this problem?
Please, help me with this
:con?
Did you install any new software....try removing unwanted software....remove the battery and try...if no go....try doing a Firmware upgrade.
I have had this happen a few times. My problem is associated with my memory card ass it occasionally reports that it is corrupted and I have to take it out, clean it and pop it back in (sometimes 2 or 3 times) which seems to sort it out.
Adam
That's happen with me always when the memory card had problems....
the only solution for that is to FORMAT your memory card
