Hi newbie here hehe,i just got my 3650 mates,so can anyone help me what are the best softwares for 3650 so i can purchase them,hope someone help thnks in advance. 😊
p.s. give your list of softwares the best one thnks again. 😊
Take some pix then mate and post them up - different lighting conditions etc etc.....
please please please..!!!!
How can you be a newbie with 285 posts here? :roll:
Anyway, all 7650 software should work for 3650 unless otherwise told...
[quote="Hankman"]How can you be a newbie with 285 posts here? :roll:
Anyway, all 7650 software should work for 3650 unless otherwise told...[/quote]
maybe he meant newbie when it comes to the 3650. :-? well, like you said, everything should fine in the 3650 that you used for the 7650. 😃
There may be some apps that wont work at first.
But those can be fixed easily by contacting developers. 😃
how to take a screenshot on 3650? :cry:
[quote="IRVING02"]how to take a screenshot on 3650? :cry:[/quote]
EASy
buy digital camera 😃
[quote="pandemonium"][quote="IRVING02"]how to take a screenshot on 3650? :cry:[/quote]
EASy
buy digital camera 😃[/quote]
digital camera?? :evil: :2gunfire:
Use fExplorer, seleQ, sCapture... what ever.
For screenshots
[quote="JyriK"]Use fExplorer, seleQ, sCapture... what ever.
For screenshots[/quote]
are you sure they work with 3650?!
[quote="IRVING02"]
are you seriuos bro?[/quote]
let me think .............................NOPE 😃 😃 😃
[quote="pandemonium"]are you sure they work with 3650?![/quote]
Cant see why those wouldnt work.
coz im using SELEQ? :evil:
Try Screentaker from Symbianware.com
Has the advantage of being freeware.
I'm using Screentaker with 7650 and it works fine
it should work with 3650 if it has the abc
im pretty sure seleQ will work and screentaker, i reackon, irv, that you just have to configure the keys to use. i doubt if the 3650 has an 'abc' key. never seen it up close. 😃
The 3650 has the ABC key, its a tiny round one on the left of the keypad. However, it hasnt got the ABC letters on it but a small pencil, but it has the same function.
[quote="MaleBuffy"]The 3650 has the ABC key, its a tiny round one on the left of the keypad. However, it hasnt got the ABC letters on it but a small pencil, but it has the same function.[/quote]
oh, alright, thanks for the info. 😃
http://www.nowarezplease.com
here is a website with some things and games. You first have to download emule from http://emule.sourceforge.net/
i would like 2 ask about the 3650 from where u bought it and how much did u bought it and how about mmc did u got 4 it an mmc and how about its camera is it better than the 7650 does the vedio can record also sound i need 2 get it i will b thankful 4 that
the pic is quite fine,but i like 3650 than 7650,coz of the mmc i got 128MB!
MY 3650 HAS ARRIVED !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i payed it A LOT but I don't care
[quote="pandemonium"]MY 3650 HAS ARRIVED !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i payed it A LOT but I don't care[/quote]
you just got it now bro? 😊
Sooooo.... what is your first impression about the device?
it great but its hard to send a SMS. great memory 😃
Arghh!! I want mine NOW!! 😉
With 128Mb of memory space, i soon learn to live with the 3650 wierd keypad layout. I have more than 20 games installed and many wav songs as well. And yet still have more than 100Mb available 😊
The picture quality is much better as well. U can select picture quality to high and still have enough space for 2000 pictures...
Already sold of my P800 because memory limitation.
Could you please post some pics taken with the camera!
ok it's like this:
1.writing sms is the worst thing I've ever seen
2.mmc is a great thing
3.IRVING02 7650 screen taker actually WORKS !
4.snails don't work
5.IRVING02,did you try to send via IR or sms some images and then did you manage to save them in your images folder??????? cuz i didn't .my save option doesn't display
I'll try some other apps and keep ya all informed
If you want me to try other apps that you used on your 7650 just ask
they are both shot at high image quality
7650
