Has anyone else tried to connect the Nokia N95 to the Sony Bravia tv? I am not sure how to do it, I have plugged in the phone and matched up the cables but I can't get anything to show up on the TV.
Connecting the Nokia N95 to the Sony Bravia
I've not got a Sony Bravia but if you have an AV button on your remote control, try it and select which source you get your picture from.
press the round button on the control and cursor down to the AV5 I think it was on mine... it was a while back tho... and I dont know where my cable is now so I cant test it...
I connected my n95 to Sony Bravia with no problems. You need to select the input using the button top left corner of the remote (the name of the input AV1 .. AV6 is written next to the input on the TV).
you can easily identify the AV input.. select that AV input on your remote while the cable is plugged into both the N95 and the TV.
an alternative is to plug it into a VCR or DVR .. say on Input 2 .. since that device gets regularly used .. you ought to be able to show its input on your TV. The select Input 2 on THAT device (VCR or DVR) it ought to show the N95 screen directly on the TV in place of your previous signal from that device.
Good luck!
I guess it really depends on 'which' bravia you have, but yeah... it should work no worries....
I found it on AV6, kind of stumbled upon it! Thanks for the help!
