Hi guys,
I have a new e61 which i could use some advice on.
1. On the standby screen are several shortcuts. can i remove some/add others?
2. I am installing games and woud like to try tibiaME but it won't load, any ideas?
3. I am on the 3 network (if that makes a diff) and was wondering if i would be able to change the new mail hot key to text messages?
Cheers,
Phil
fev wrote:1. On the standby screen are several shortcuts. can i remove some/add others?
Yes. RTFM.
Ask the publishers of tibiaME?
desertrat wrote:Yes. RTFM.Ask the publishers of tibiaME?
You having a bad day m8?
shortcuts, menu key..settings..phone..standby mode..active standby apps
also from stanby mode you can set the left and right softkeys.
