Configuring Exchange ActiveSync on P990i
7 replies · 21,787 views · Started 25 October 2007
This thread included a poll: Was the article useful?
For all those folks who have not been able to configure Exchange ActiveSync on P990i provided by DataViz Corp.
I am posting this article on the Forum because i spent 3-4 days with the IT department of my company trying to figure out the issue but in vain. Sony Ericsson support sucks and was of no use. Finally i resolved it myself ! If this post helps you please acknowledge !!!
Pre-conditions:
1. Your companys mail server should be MS Exchange Server 2003 with SP2 Installed.
2. Mobile access should be enabled for your profile on server. By default when profile is created it is enabled.
3. You have OWA (Outlook Web Access) enabled without use of VPN.
For more details / troubleshooting on configuration of MS Exchange Server for mobile access please email me.
Setps:
1. Install Exchange ActiveSync on P990i. This SIS file comes bundled with the phone or you can download it from the Sony Ericsson or DataViz website.
2. Make sure you have a working GPRS / 3G connection configured on your P990i
3. You will now require the following information to configure the software. Open the software on the phone and enter the follwing.
Username : Your NT / Login ID and password which you use to login to your desktop in office.
Server: Your exchange server address. This is usually the address you use to o access OWA on IE. Remove the "https://" part from the address and type under the server address field.
Domain: You can leave this blank.
Use SSL Check this box (This is for the secure connection)
Hopefully if things are correct at the server end and you have entered the correct settings in the setup this should get you going....Please feel free to post if you have any issues.
Note:
Before syncronizing your phone make sure you backup the contacts. There are chances that synch. might result into duplicates for the first time and you may have to manually delete / modify them.
Cheers ! Happy messaging !!!
Hi bagaria,
Its great. I have one query. It was working very well, when i first time install the softwarer. It worked for 1 month or so. One day i had to reset the master of my P990i. Now when i do it it constantly give me an error that please check your server name. I don't know why
manisad wrote:Hi bagaria,
hi !
I guess it might be probably because :
1. you re-installed a different version of software on the phone which is not compatible
2. You might have entered an incorrect username and password on the account setup.
3. Or you might have changed your office / NT ID password which expires after certain no. of says as per the admin. policy.
- If none of the above is true ....email me / post the exact error msg. you get.
- Also if you have push enabled on the account settings, try disabling it and synch manually and try.
I have installed the same version, which i downloaded from sonyericsson site. If you know anyother version please let me know.
i am enterring same user name and password, which i am using to access my email on pc
error: preparing to sync connecting to internet...linking to Exchange Server.... Connection estalished! Connecting to Exchange.... Server error: 403 Server Refused connection! Please try to sync again. if this error persists, contact your exchanger server admin.
How to enable push button in account setting i dont know. can you let me know
thanks
bagaria wrote:hi !
manisad wrote:Hi,
thanks
hmmmm....
403 error is kind of strange. See this link for further troublshooting steps...
http://support.dataviz.com/support.srch?docid=14010
Other error codes are explained in this link:
http://support.dataviz.com/support.srch?docid=13679&pid=2000
It might also be possible that your exchnage server admin. in office has disabled the mobile sync. on the server settings.
Follow this article for settings on the serverm you can fwd. it to you IT team and cross check.
http://www.msexchange.org/tutorials/Managing-Mobile-Access-Exchange-Server-2003.html
You can download the correct version from here...
http://www.dataviz.com/downloads
Hi
I had tried to follow the same steps as you mentioned but unable to configure my activesync with P990i.
I'm getting error while sync. Please help...
Starting user-initiated sync.
Preparing to sync
Start synchronization...
2.013 (334)
10/03/2008 3:04:47 pm
Preparing to sync
Connecting to Internet...
Linking to Exchange server...
Connection established!
Please try to sync again! If this error persists, please make sure that the Server name is correct and that you are in a good coverage area
0x7370C07 (httpErrTransactionTimedOut)
Sync failed!
10/03/2008 3:06:49 pm
Last sync: Error - see log
ClearMessageEntriesL() error: 0x0
mtminstaller eror: 0x0
DActiveSyncEngine::CanPerformSync() - Priority : 0x1
DActiveSyncEngine::CanPerformSync() - Finished : 0x1
Preparing to sync
CanConnectToInternet() - Checking Connection.
IAP : Ad-Hoc Bluetooth PAN, Type : LANService, ID : 4
IAP : Airtel MMS, Type : OutgoingGPRS, ID : 6
IAP : Mobile Office, Type : OutgoingGPRS, ID : 7
IAP : Airtel Live, Type : OutgoingGPRS, ID : 8
SNAP : Internet, ID : 1
DSymbianV2InternetConnectEngine::SetupConnectionPrefs() - SNAP ID : 1
DSymbianV2InternetConnectEngine::RunL()
mCurrStage=0x1
statusCode=0x0
DSymbianV2InternetConnectEngine::RunL() - Network Status :0x1
2.013 (334)
10/03/2008 3:09:08 pm
Preparing to sync
DActiveSyncDataManager::PrepareForCalendarSync()
DActiveSyncDataManager::PrepareForContactsSync()
DActiveSyncDataManager::PrepareForEMailSync()
DSymbianMessageManager::HandleSessionEventL() - EMsvServerReady
DSymbianOutlookMessage::GetTempProcessingFolderId() - failed to do GetTempProcessingFolderIdL() with ERR: 0xFFFFFFFFFFFFFFFF
DSymbianMessageManager::CompleteMsvSessionInit() - Failed to prepare the TempProcessing folder with ERR: 0xFFFFFFFFFFFFFFFF
DActiveSyncEngine::RunTask() - Ready for StartSync
EstablishInternetTimeoutInternalL() - Time Out Sec : 2100
IAP used : 0x8
Bearer ID : 3
MODEM Bearer
LastSocketActivityTimeout : -1
LastSocketClosedTimeout : 2100
IAP used : 0x7
Bearer ID : 3
MODEM Bearer
DSymbianV2InternetConnectEngine::Connect()
IConn - KStartingSelection: 0x0
mCurrStage=0x2
statusCode=0x0
DSymbianV2InternetConnectEngine::RunL() : KErrNone - Connection created succesfully.
DSymbianHTTPSession::InternetConnect_RecievedResponse() - Connected To Internet
DSymbianHTTPSession::MakeReady() - Removing Validation Filter
SetupProxyIfRequiredL() - Preparyng PROXY info.
SetupProxyIfRequiredL() - Turning Proxy OFF
DActiveSyncEngine::PrepareOptionsCommand() : 0x2
DActiveSyncEngine::PrepareActiveSyncCommand() : 0x2
Initiating Submission of the HTTP Transaction (Symbian)
URL (Built) : https://mail.fadvos.com/Microsoft-Server-ActiveSync?User=sbisht&DeviceId=359593007430953&DeviceType=RoadSyncClient
DSymbianHTTPTransaction::SubmitSymbianTransaction() - SubmitL() successfull.
Gprs connection successful: 0x8
IConn - KFinishedSelection: 0x0
IConn - KLinkLayerOpen: 0x0
DSymbianHTTPSession::RunL() - Forcing connection to terminate!
DActiveSyncEngine::HTTP_ReportError() - 0x7370C07
Sync failed!
10/03/2008 3:11:10 pm
DStargateAppUi::ActiveSync_ReportError():0x7370C07
DSymbianHTTPSession - timed out
DActiveSyncEngine::CancelSyncInternal() - STARTED.
DSymbianHTTPTransaction::CloseSymbianTransaction() - Closing.
DSymbianHTTPSession:😃isconnectFromInternet()
DSymbianHTTPSession:😃isconnectFromInternet() - Closing HTTP Session
DSymbianV2InternetConnectEngine::CloseConnection()
DActiveSyncEngine::CancelSyncInternal() - AdjustPrefs.
CancelSyncInternal() - FINISHED.
mCurrStage=0x2
statusCode=0x0
DSymbianV2InternetConnectEngine::RunL() : KErrNone - closing connection.
DSymbianV2InternetConnectEngine::CloseConnectionInternal() : Disconnecting from the internet.
Disconnect Finished!
Could you help???
Please check your account settings again. You might have changed your desktop password but forgotten to change it on your phone under account settings.
jaipsharma wrote:Hi
Preparing to sync
2.013 (334)
Preparing to sync
Sync failed!
Preparing to sync
mCurrStage=0x1
statusCode=0x0
2.013 (334)
Preparing to sync
IAP used : 0x8
Bearer ID : 3
MODEM Bearer
IAP used : 0x7
Bearer ID : 3
MODEM Bearer
mCurrStage=0x2
statusCode=0x0
Sync failed!
mCurrStage=0x2
statusCode=0x0
Could you help???
- What are your server settings on Exchange Server ? Did you configure your account properly? Is OWA enabled for your id?
- Did you make sure that the pre-conditiones mentioned in the post above are met by the exchange server you are on?
