N93i won't turn on
1 replies · 6,044 views · Started 26 October 2007
I had some errors with my n93i, it would reject my sim card, and others on my carrier. So I upgraded the firmware from the nokia website, and during "the usb device attached malfunctioned". When i turn it on now, the NOKIA logo on the front LCD loads, btu stays like that. ANy help would be appreciated
I'm no expert or anything, but if your USB cable has faulted up DURING the firmware update, then its probably a very bad thing. Even nokia update manager tells you that.
I read somewhere on the forum about a system reset by holding some buttons. Perhaps you should try that?
